Old 06-09-2004, 09:02 PM
Chahlie's Avatar
Default Finishing My first Santa
Hi All,
Well I am ready to finish my first Santa...I plan on painting it with acrylics as recommended by the book I took the pattern from...My question at this point, the carving has acquired some smudges from handling and such, do I need to seal the wood with something like Z-lac or wipe down carving with acetone or what?
Thanks for your help and hoping to have pics of the Santa painted on webshots soon!
"let the chips fly!"
http://community.webshots.com/user/chahlie
Old 06-09-2004, 10:01 PM
jamesfa's Avatar
Default Re: Finishing My first Santa
i'm sure there are diff. methods used by various people but the following i picked off the net when i started.
1)warm water &2-3 drops of liquid washing detergent(unscented)
2)dip a toothbrush in soapy water and scrub carving,do not immerse carving in water.
3)rinse carving with fresh clean water to remove soapy residue
4)towel off water & blot carving-let dry overnight.
once cleaned wear a thin cotton glove to handle carving so as not to transfer any oil from your hands to clean carving.
you can then seal carving with the sealer of your choice
zinesser bulls-eye shellac(12% shellac)
KT super sealer
Deft spray lacqer
(others on this board have mentioned a Krylon product to seal a carving )
washing and sealing will raise the grain-use a 3m scotch brite pad to eliminate any glossy areas & raised grain.
now your ready to paint
some people like the wood to show thru so the dont seal their carving-maybe they can offer their technique
Old 06-09-2004, 10:44 PM
MelNM's Avatar
You might also try boiled linseed oil to seal it, I like the results I get from it. Also when you paint it don't use the acrylic paint at full strength, specially if you want the grain to show through, I water mine down to the consistency of milk, then you can put one coat at a time till you get the look you desire.
I have also used a scrub brush when cleaning my carvings, along with what James said.
He who laughs last probably does not get the joke.
My Gallery
Old 06-28-2004, 06:56 PM
fingers
Guest
Posts: n/a
After towel drying, i use a hair dryer, re-sand with 400 sandpaper, blow it off with canned air used for cleaning key boards and seal it with Krylon 1303 and paint using the washed look.
Then I hit it again with a light coat of 1303.
Santa Ornament's (steps to finishing) Mark Gargac Wood Carving Tutorials 26 12-29-2006 07:55 AM
finishing Walt Wood Finishing and Painting 10 10-26-2006 05:52 PM
Finishing vonwhatever Wood Carving for Beginners 1 03-12-2006 01:15 AM
finishing Alice in Wonderland Wood Finishing and Painting 0 01-17-2005 05:49 PM
finishing santa icarve2003 Wood Finishing and Painting 8 02-25-2003 03:18 AM
