Old 06-19-2009, 03:48 PM
yaki's Avatar
Default Edge of a blade broken
Hi
I just broke the tip of my new Knife
well I guess I tried to pull out a large piece of wood with the tip
what sould I do to fix it?
Thanks
Old 06-19-2009, 04:08 PM
OkieHunter&Three's Avatar
Default Re: Edge of a blade broken
I would reshape the tip on the knife, just be careful and not heat it up. I think I would just use a diamond hone. It doesn't look that bad and should reshape fairly easy. Just my 2 cents worth
Old 06-19-2009, 05:13 PM
Tom Ellis's Avatar
chipchaptom
Hello,
You can grind the backbone, or top back down to the cutting edge, instead of trying to sharpen all the way back up to the tip of the break. Guess you will just have to carve shorter pieces now.
Good luck, TOM
Old 06-19-2009, 05:35 PM
Claude's Avatar
As Tom Ellis says, grind off part of the back towards the tip - don't try to grind off the edge. I have a Flexcut detail knife that I've dropped on the concrete floor three times, each time losing about 1/8 inch of tip. I just ground the back down using a sanding drum - took five minutes or so...touched up the edge on the strop and ready to carve.
No matter what type of grinding device you use, keep a container of water nearby. I would make a 3-4 second pass on the sanding drum and then dunk into the water to cool it off. If the tip turns blue, you've just lost all the temper in it. A good rule of thumb is grind three seconds, dunk three seconds, then repeat.
My web site
Not Broken-Broken Curtscarving General Wood Carving 17 05-09-2009 06:37 AM
New Knife. blade will not keep an edge. aulddiy Woodcarving Tools, Technology & Sharpening 12 12-30-2008 01:48 AM
What would you do - broken blade? keithlong Wood Carving for Beginners 6 09-24-2008 08:48 PM
Broken Dreams Ashbys Relief and Chip Carving 7 11-21-2007 10:40 PM
Broken carving Kenny_S General Wood Carving 5 05-20-2003 09:38 AM
