| Found the Fox?
| General Wood Carving |
04-03-2005, 08:10 AM
| | Member | | Join Date: Apr 2002 Location: tampa florida
| | Dust collector I'am gonna move into a townhome. I'll loose my garage and the boss says I gotta do something about cleaning up act.
I am asking for opinions on dust collectors that can be used in the home or in a screened area. Noise is a concern followed by effeciency and mounting system such as in a table top, or portable so I can move it around.
Your comments are appreciated.
save a finger, wear a glove
04-03-2005, 08:49 AM
|  | Moderator | | Join Date: Jul 2004 Location: (Whooping Hollow) Alpena, Northwest AR
| | Re: Dust collector I have tried several different collectors. My advice is, that unless you can exhaust the dust to the outside, don't power carve in a room where dust will be a problem. The biggest problem is acutally holding the piece in position for the collector to work (what's efficient for the carver is not necessarily efficient for the collector). But, no matter how hard you try, nor how good the collector, some dust will get through the collector's filtration system. This advice came from my brother who's airconditioning business also works with cleaning up buildings with ventilation problems. I was not totally convinced until I started to carve some cedar. The filter became red with dust. Easy to see. Reminded me to clean the filter very often. Thought it was doing a sufficient job for me. No visible dust. But, then, after a week of carving, found a fine red patina covering everything in the room. I continue to carve in the house, but have put my collector where it exhausts through a window. This helped. But that is still the dustiest room in the house. A screened area should be perfect.
Reason: additional information
04-03-2005, 09:15 AM
| | Re: Dust collector Thanks for the quick reply, Paul. I didn't think about powering/sanding only outside. I will think about designing a means of discharge from the screened in area and do my carving inside. I'll still need to find a quiet collector.
Thanks
04-03-2005, 09:45 AM
| | Re: Dust collector I bought a filter "box" from Grizzly, was only 79.00 I think, its quiet and really pulls in the dust and the fumes from the woodburner..this is the single fan style, they have a double fan for I think 129.00 . I would recommend this. but as a precaution, when I am burning or using a foredom or dremel...I also use the face mask....it was 29.00, works great, doesn't fog up my glasses and is called a "dust foe"...........dave |
04-03-2005, 10:50 AM
| | Sanding Class Dropout | | Join Date: Dec 2004 Location: Northern Ontario, Canada
| | Re: Dust collector Not a power carver so I don't use any dust collector systems, but depending on the size of the piece you are intending to work on, maybe a "downdraft table" might meet your need.
Check out this article from the Woodcarvers on-line e-zine at; http://carverscompanion.com/Ezine/Vo...ol3Issue3.html
And look for ;
Thierry's "Air Curtain"©
Build it Yourself...
An Efficient, Portable Power Carving Station
by Thierry Varem-Sanders
Hope this is of some help.
OG |
04-13-2005, 07:42 AM
| | Re: Dust collector Thanks, Og. This Fits The Bill And The Website Is Very Interesting.
Our "design Engineer" For The Carving Club Is Making Me The Carvin Curtin Out Of Plexiglass.
04-13-2005, 10:08 AM
| | Re: Dust collector You are most welcome, just trying to help where I can.
OG. Quote: |
Originally Posted by FINGERS Thanks, Og. This Fits The Bill And The Website Is Very Interesting.
Our "design Engineer" For The Carving Club Is Making Me The Carvin Curtin Out Of Plexiglass. | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -4. The time now is 06:23 PM. | |
