General Wood Carving | |||
I just feathered in the head of a barred owl and, from handling it I have created a mess with pencil marks, eraser markes, etc. It is dirty and unattractive. I want to do a little woodburning on it and then finish it naturally. I want to clean it without sanding off all of the featherwork. Any ideas from the experts who have , no doubt, experienced something like this? Thanks Dave |
I always scrub them with a denture brush and "Simple Green" soap. Seems to remove all the oils and grime from being handled really well.
I put liquid soap in a sink and fill with water so the soap bubbles, I then dip an old tooth brush in the bubbles, (not the water) scoop up bubbles on the brush and scrub the carving. Hope this helps! Dave |
I use a bar of white bath soap and an old toothbrush. Dampen under the faucet, scrub with the brush and then rinse. You can dry it quickly with a hair dryer. If this raises the wood fibers and it feels rough, give it a good scrub with a wadded-up brown paper grocery bag and it'll feel smooth again. Claude |
Thanks to all of you for the helpful information. I will try it and get back to you. Most of the discoloration is due to the fact that I used carbon paper between two pieces of the carving in order to see where the high spots were. The head on this owl will set in a socket like a ball and socket so I will be able to rotate the head to any position. I have a similar woodturned wood version of this concept that I found while in Germany and have been fascinated with it since I bought it 6 years ago. If it turns out as I hope, I will post it in the future. Again, thanks Dave K |
I had Simple Green so that is what I tried. It worked great. The head looks as good as it did before I started carving feathers into it. Thanks again \ |
| Quote:
| Newly finished | Darrell Riggins | Animal and Bird Carving | 14 | 10-11-2011 04:58 AM |
| Clean Shaven Egg Head | Eddy-Smiles | New Projects and Works in Progress (WIP) | 30 | 11-19-2010 04:48 PM |
| Newly Carved Sticks | ten99j4 | Stick and Cane Carving | 4 | 10-23-2010 09:19 AM |
| Has anyone ever just carved a HEAD? | jillsy | General Wood Carving | 18 | 11-15-2009 10:49 AM |
| newly married | shade_skyhi | Welcome Members | 8 | 06-17-2009 03:07 PM |
