General Wood Carving | |||
I have a beuatiful piece of manzanita root I want use to mount a carving on. I want to expose the wood underneath the dirt, grime and oxidation but am uncertain as to cleaning and finishing. With the irregular surface it seems to be a huge project. Can anyone share thier success stories as to how I might accomplish this task?? Thanking you in advance Dandy |
I do not know your root living in the North. But when I want to clean anything like this ,I use the water pressure, going gently from a distance to see how it works and getting closer and closer as I feel it is safe ,so I won't loose any wood. I have heard also to try a sand blaster????? I hope this helps Alice |
This wood grows in N.Cal where my dad lives and is quite rezillent even to fire.I would be afraid to to get a little tough with it.Davy
I use a flapsander called a Sand-o-flex. Does a pretty good job. I haven't tried this but I believe a power pressure washer would do a pretty good job. Don't use a sandblaster. DAMHIKT. Doug |
Dealers put that stuff into old clothes dryers along with a few smooth river rocks to clean it up prior to selling. Tell your wife I said it was okay to do that!! (Only kidding!!)
Thanks folks for the ideas. I have a pressure washer, so I think I,ll try that. Lynn, If I try your idea I,ll have to find a new home!! ![]() thanks!! Dan D. Dandy---Get it? |
Dan, I haven't tried the prssure washer, it was just an idea. Let us know how it works. If it works you will have to let it get good and dry and then I would suggest spraying it with a can of Deft. Doug |
Not necessarily Dan! Depending on how old your dryer is your wife might be very agreeable!!!
Dan D.-- Let us know how the pressure washer worked for cleaning the Manzanita root. Inquiring minds want to know. If it does a good job I have about 20-25 and I can fire it up one time and clean them all. Doug |
Doug, I haven't had a chance to get my powerwasher out and running yet. I Haven't used it for a year so------! I will certainly let you all Know. I want to be a bit careful with it too. Dan |
| cottonwood root | morgan | Carving Wood & Materials | 5 | 01-27-2009 05:07 PM |
| cottonwood root | abisso | Carving Wood & Materials | 2 | 03-21-2008 12:51 PM |
| cottonwood root | abisso | General Wood Carving | 7 | 02-11-2008 01:34 PM |
| Routing Manzanita Root | nadcarves | Carving Wood & Materials | 4 | 01-02-2008 12:56 AM |
| Getting to the Root of the Problem! | Lynn O. Doughty | Caricature Carving | 13 | 06-19-2006 07:51 AM |
