Old 05-01-2006, 10:45 PM
Default To clean or not to clean?
I was just wondering how many people wash/scrub thier carvings prior to painting/priming/staining? Doesn't this raise the grain on fine detailed work? I know after cleaning you are supposed to sand with fine grit or paper bag type material but if you have fine detail wouldnt this still ruin it?
Old 05-01-2006, 11:23 PM
Thomp's Avatar
Forum Mentor
Default Re: To clean or not to clean?
i been using lynn droughtys wet on wet wash method of painting, and i didnt find it to raise the grain on my last few carvings, but it was some really great northern basswood, from henkei this last batch from him is really fuzzy ill know more by the end of this month.. when i get these 7 other projects done;.
Thanks Thomas,
Email:
thomp51la@gmail.com
Old 05-02-2006, 08:29 AM
Callynne's Avatar
I've heard of doing that, but I've never seen the need to. When I'm done carving I sand my work, not totally smooth sanding (except for 'flesh areas' like faces and hands, for some reason I like them smooth). The sanding I do still leaves them looking like a wood carving, just not as distinct as if I hadn't sanded at all.
Washing them could definitely swell the wood some, depending on how wet you actually got it, but I would think the detail would be there when the wood dries. I just don't see why you'd need to wash them, be interesting to hear others thoughts on this! Deborah
www.deborahcall.com
Old 05-02-2006, 10:22 AM
After I'm done carving and sanding, I do clean my piece with warm soapy water and little stiff brush. This helps take off little bits and pieces (apparently also oils in the hand) I never soak the pieces and they dry fairly quickly. When they dry, I resand very lightly, brush off, and then start priming.
I never would have thought about doing this on my own. I read about doing it in a few books (I think by Ron Ransom). It doesn't hurt the piece that I can tell and I do like the look of it after being cleaned. I always have to debate whether or not I wanna paint it or leave it natural.
Old 05-02-2006, 10:48 AM
Dirt seems to collect only on the ridge of the individual chips so it's only necessary to clean that part of a carving. To do that I use a Sand-O-Flex wheel with 380 grit slitted paper. Before using a new role of paper I take an old piece of wood and hold it into the wheel till the little fingers of sandpaper are frayed and worn. This way I don't have to worry about removing too much wood. I've been using this method for umpteen years without a complaint so far. I will admit that I've only used this on my figures so it might not apply to whatever you're carving.
Out West Woodcarving Blog:
Out West Gallery
Old 05-02-2006, 11:31 AM
Doug Ridley's Avatar
Doug Ridley
I go over my carvings with the same thing Lynn does if it is a large carving. The sandoflex is a VERY useful tool for many applications. On some smaller ones I use a brown defuzzer pad on a mandrel. Since Mary paints mostly with oils, she paints right on the raw wood, often rubbing pretty hard with an old rag to actually force the paint into the wood and and at the same time remove excess paint.
Old 05-02-2006, 07:29 PM
Bartster's Avatar
i wash my carvings when i am ready for painting the way i do it is this;
run carving under water just to get wet alittle
put some dial liquid soap on brush and scrub to a good lather then rinse off the soap and towel dry just to get the heavy moisture off. then i either paint it or just paint the eyes and teeth,and let dry and then apply the stain and paint over that with thin washes.
hope this helps
bart
Old 05-02-2006, 10:00 PM
Blake Lunsford's Avatar
I use the same method as Bart and found on the Indian with Wolf Cape piece that I completed that the grain really shows through after you wash it. This wood was also purchased at Hineke. You can see it under my Gallery in "Carver Galleries". Hope this helps!!
Blake
Blake Lunsford
https://sites.google.com/site/lunsfordcarving/
Very funy, clean GAcarver Off Topic 11 02-05-2007 08:27 AM
clean strops Frank Seeley Wood Carving Tips and Techniques 12 11-09-2006 11:36 AM
A Clean Shop Hugh Off Topic 36 09-01-2006 08:47 PM
Clean leather? MDWine Woodcarving Tools, Technology & Sharpening 16 12-03-2005 02:01 AM
What will clean up Pine Tar Colin-Partridge General Wood Carving 6 05-20-2005 11:40 AM
