General Wood Carving | |||
other than garbage is a broken band saw blade reusable or good for anything
they can be re-welded and used again if they are sharp & not kinked. Some guy on you tube cuts them a couple of inches long, puts handles on them so they look like a 2 man saw and sets them in a small branch for woodland scenes. Denny |
Laine, If it is still sharp, you can taper and overlap the ends, and silver solder them, and should be good to go. I repair mine twice, then they are generally too dull to worry about. The lumbermen sounds like a good idea. Tom |
thanks Tom and Denny , I will give both ideas a try laine, |
| Band Saw Blade Recommendation | MWhittlinman | Woodcarving Tools, Technology & Sharpening | 7 | 09-15-2009 09:51 AM |
| Edge of a blade broken | yaki | General Wood Carving | 3 | 06-19-2009 05:35 PM |
| Band saw blade | James A | Woodcarving Tools, Technology & Sharpening | 9 | 11-10-2008 08:40 PM |
| What would you do - broken blade? | keithlong | Wood Carving for Beginners | 6 | 09-24-2008 08:48 PM |
| What do you do with broken Band Saw blades | Merle Rice | Off Topic | 6 | 04-11-2007 04:20 PM |
