General Wood Carving | |||
I've tried to find a bench top speed controller for my Wecheer but all I can find is one for Foredom that won't work. Does anyone know if a variable speed bench top control for a router or other piece of equipment will work. I can't keep a steady speed with the variable speed foot pedal. Harris |
I'm not sure how many amps you're drawing with that,,,but I've used ceiling fan speed controllers to modulate a number of things. These are rated at around 15 amps. I've used them on burners and such which draw quite a bit of power. A regular dimmer won't handle it. I simply use an outlet box,,,tied in the dimmer,,plugged in the tool and off I went. A note,,,I'm not an electrician and can't vouch for how safe this is,,,but it worked for years for me. If you decide to try it I have to say I can't be held responsible. Just because I'm dumb enough to do it doesn't mean you should too!. But I have to say,,,it worked really well. |
| High Speed Air Turbine Carvers | woeco | General Wood Carving | 12 | 02-20-2009 12:04 PM |
| slow speed elec. motor | Hi_Ho_Sliver | Woodcarving Tools, Technology & Sharpening | 6 | 11-29-2007 06:50 PM |
| High speed carving equipment | Guest | Woodcarving Tools, Technology & Sharpening | 6 | 12-31-2005 08:54 PM |
| mciro grinder speed ?????????? | Folkcarver | General Wood Carving | 2 | 02-10-2005 07:31 PM |
| Speed control for either Dremil or RTX | Guest | General Wood Carving | 3 | 06-27-2003 08:34 PM |
