Old 03-20-2008, 09:36 PM
feb's Avatar
feb feb is offline
Default bear cub over water
just finished this cub going over a stream. It's all out of basswood except the log is real birch, it is painted with acrylics and i used envirotex over the painted water. I also added 2 coats of matty finish. Hope you enjoy.
click below album 2
Feb
Old 03-20-2008, 09:54 PM
tucker1931's Avatar
Default Re: bear cub over water
Well sir, you did a real fine job on your little bear on the log, I really don't recall seeing a bear that color but that's secondary, he looks very realistic given his present situation, I think you did very well.
Old 03-21-2008, 09:07 AM
Irishman's Avatar
A passion for carving
Nice scene you set up there Feb. Your in the "bear carving" mode now I see. You should put a fish in there somewhere's with all the work you put into putting water in your scene.
Patrick
Old 03-21-2008, 02:08 PM
feb's Avatar
feb feb is offline
Patrick, Iwas going to put another bear on the ground with a fish but changed my mind.
Tucker 1931, I can't tell colors the bear is a thinned out black a friend helped with the colors of the ground and water. Thanks for looking.
Feb
Old 03-21-2008, 02:33 PM
Bartster's Avatar
feb,
good work on the bear scene,
bart
Old 03-21-2008, 02:59 PM
gene-messer's Avatar
You did a good job Feb ... nice little scene and fun to look at ..
Good job ..
Gene
G.M.
Old 03-21-2008, 08:36 PM
feb's Avatar
feb feb is offline
Thanks, Bart and Gene
Feb
WIP- Chainsaw Bear (White Ash=Polar Bear?) Lightningbolt New Projects and Works in Progress (WIP) 26 04-09-2007 05:19 PM
daddy bear and baby bear steve in houston Holiday 1 12-07-2006 07:06 PM
I'm in a bit of hot water... MDWine Off Topic 5 05-09-2006 09:23 PM
Over water/under water relief carving Gray_Fox General Wood Carving 3 11-22-2004 06:57 AM
Water???? Jeff Wood Finishing and Painting 6 02-15-2003 03:09 PM
