Old 06-11-2009, 01:27 AM
yaki's Avatar
Default band saw Vs scrall saw
Hi All
what would be Better for carving roughouts band saw or scroll saw?
(for Caricature small figure)
Old 06-11-2009, 01:55 AM
Dan S's Avatar
Sir Bleedsalot
Default Re: band saw Vs scrall saw
A large scroll saw can cut wood up to 2" thick. This is fine for small figures as long as you keep you dimensions this size or smaller. A bandsaw does not have this restriction. Even a small saw will allow you to cut up to an 8" block. For my money I'd get the bandsaw.
If you want to save a bit, have a look in your local paper as well as craigs list. There are some really good deals out there on used tools.
Take care,
Dan
Old 06-11-2009, 03:00 AM
yaki's Avatar
Thanks dan
What about the noise ,is band saw is mouch loader then the scroll saw?
Old 06-11-2009, 07:32 AM
RUssL.'s Avatar
I don't find a band saw particularly noisy, compared to say a table saw.
My shop-vac is much noisier than the band saw. :-)
A scroll saw is a bit less noisy perhaps than a band saw, but the versatility of the band saw outweighs that (I think).
Having said that, I am not aware of any "small" band saws that will cut an 8" thick piece of wood.
14" band saws, the typical home-shop size, will only cut 6" thick (without a "riser block", which will double that thickness).
I have what might be considered a big "small" band saw, a 12" Sears Craftsman. It will cut up to 5.5" thick wood.
A 10" bench top band saw ( a true "small" band saw) will usually cut 4" to 4 &1/4" thick wood.
Good luck on your choice.
RussL.
Old 06-11-2009, 07:44 AM
Mudbone's Avatar
Member in training
I concurr- My 12" JET will only cut 6" stock...
Old 06-11-2009, 11:05 AM
Banned
I have both. I use the scroll saw once or twice a year. I use the band saw every day. Of course it depends what you plan on doing primarily. Resawing wood,, roughouts for pretty much any size general cutting etc. I'd get a bandsaw. Very versatile.
Thinner scroll work,,intarsia.. pierced pieces,, get a scroll saw. Using one to do thicker work ,,,well,, it can do it,, but blade flex,etc.,, it's asking a lot of it.
Plus,, most band saws on the market today have "riser blocks" available. Turned my 14 inch saw, capable of cutting a 6 inch high block into one able to cut 12 inches high. Much cheaper than buying a saw able to cut this height from the beginning.
Old 06-11-2009, 11:35 AM
urbansheepdog's Avatar
Hi Yaki
I think if all you were wanting to rough cut was small caricatures then a scroll saw will probably suffice. In saying that, I bought one years ago and apart from plugging it in to test it, that was the only time I used it. A bandsaw is going to give you far more versitility. I upgraded mine to a 2HP at the turn of the year and it's almost become the hub of the workshop!
If you've got the space and the cash I'd go for a bandsaw. Just my tuppence worth!
cheers the noo. Simon
Old 06-11-2009, 10:16 PM
Gulf Coast Handyman's Avatar
I use both, but mostly use the band saw. The scroll saw is great for ornaments, pins etc.
Dave
Old 06-11-2009, 10:24 PM
toycarver's Avatar
Girl Carver
I'd say get the bandsaw. I've cut lots on both. For cutting blanks I think you'll be happiest with the bandsaw.
Kris
WCI gallery:.
Old 06-11-2009, 10:59 PM
Iowa Carver's Avatar
Knife Nerd
I definitely would be lost without my Craftsman 12 inch bandsaw. I wouldnt mind having a good scroll saw for small stuff.
corey
Visit My Website at:
http://theiowacarver.blogspot.com/
Friend My On Facebook
band saw? James A Woodcarving Tools, Technology & Sharpening 8 09-26-2008 01:47 AM
band saw vs ? kiwibarb Woodcarving Tools, Technology & Sharpening 13 01-13-2008 12:54 AM
Help with Band Saw jillsy Woodcarving Tools, Technology & Sharpening 19 12-24-2006 06:35 AM
Dog band whittlewomen New Projects and Works in Progress (WIP) 17 11-10-2006 01:58 PM
Band Saw Which One? Mottles Woodcarving Tools, Technology & Sharpening 82 10-13-2006 05:27 PM
