Tony....Thanks for your interest in my work. It costs nothing to register on my blogsite. You do have to type in the matching letters to post though. That keeps out all those Terrorists who are after me for carving that Suicide Bomber!
I too painted for quite a long time before taking up carving. I just transferred my watercolor techniques over to wood and it worked out pretty good. Once the carving is done I soak it in water and paint it while wet. That draws the paint down into the wood and give it that soft, stained apearance. Once the carving is painted and completely dry I brush on a coat of Poly Urethane satin varnish, wiping off any shiny areas with a paper towel. Don't use a cloth as it will leave lint behind. I never use spray varnish as there are so many raised and lower areas on a piece it is impossible to get an even finish. The old brush is the best way...trust me.
The feathers are carved and attached and then removed, painted and then reattached once everything is finished. The braids are integral to the piece except where there is a grain conflict and then I will attached them for added strength.
I get my "Low Domed" tacks from
www.crazycrow.com. Call them and they'll send a catalog for free. Lots of stuff in there to use. I just ordeded a package of all their tacks so I'd have a selection to choose from depending on the project. The finish doesn't really matter as I buff it off prior to painting so the paint will hold better. The buttons on his coat are small decorative tacks also.
His pendants are carved and painted. I did put a little twist of darkened wire out of the neck piece to add a little interest. It's those little things thak make a piece look really sharp.
Some might think the way I do my add-ons or attach extra wood is not ethically correct. Well, I didn't get into this to be ethically correct I came here to have fun and that's what I do, have fun!
Please...don't hesitate to ask questions. I'll help you in anyway I can.
