Re: scroll wood blanks Roy, if you do not want to use plywood you are much better off gluing up you own blanks by far. First you can glue any size you want. Second you get a more stable blank. Wide boards especially that wide will cup and bow no matter what spicies it is. There are very few types of wood that wide anyway. If you use 1/4 sawn lumber you will even take out more of the cupping. To glue a blank all you need is good carpenters glue, clamps, and a way of sawing good glue joints on the edges of the boards. Today you can get a good glue joint using a good table saw blade or if you have a jointer that is the best way. Good luck JTTHECLOCKMAN
John T.
