Simple question from a newbie Hi All,
I have been having a ball doing Gene Messer's tutorials from square blocks of wood. I have a question, if a tutorial or pattern starts from a roughout - could you do that by hand - create the roughout - rather than use a bandsaw? For example, in Gene's tutorial Carving the Flat-plane style Santa, Gene gives a pattern, then it looks like he cuts out the pattern on a bandsaw. Now if I don't have a bandsaw, I should be able to get to the same roughout using a knife (albeit it will take longer). Is that a correct assumption?
Again, I can't say enough thanks to Gene for his great tutorials and You-tube movies.
All the best
Chris |
