  3 links from elsewhere to this Post. Click to view. #1
Old 12-02-2003, 02:13 PM
Guest
Guest
Posts: n/a
Default Sharpening/honing Speedball gouges
In a recent WCI several carvers where using a Speedball 1mm V-tool for fine lines. Last weekend I picked one up and found myself wondering wether I should just hone the rough ground edge (I think it is ground at what you wood call an obtuse (forward) angle) or do you re-shape it to a right angle I am used to with standard gouges? Your experience would be appreciated, as I perfer carving to grinding.
Thanks!
Old 12-03-2003, 12:23 AM
whittlinwit
Guest
Posts: n/a
Default Re: Sharpening/honing Speedball gouges
It could possibly benefit from some gentle honing.
I wouldn't change the angle unless it fails to work the way you want it to.
Speedball tools are made to cut at a low angle and the grind is proper for that. If you need to use a steeper angle, then you might regrind it perpendicular to the shank.
I would guess with a 1mm V it wouldn't make much difference.
Old 12-03-2003, 04:05 PM
clifford_parker
Guest
Posts: n/a
I use a speedball V-tool for fine detail lines and I just hone it on the hard arkansas stone and strop it just like I do my 'regular' tools.
I wouldn't change the angle but honing and stropping seems to help any tools, even those with a 'factory sharp edge'.
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f33/sharpening-honing-speedball-gouges-2186/
Wood Carving for Beginners [Archive] - Page 16 - Woodcarving Illustrated Message Board This thread Refback 12-21-2008 10:25 PM
Wood Carving for Beginners [Archive] - Page 14 - Woodcarving Illustrated Message Board This thread Refback 09-20-2008 03:14 PM
Wood Carving for Beginners [Archive] - Page 2 - Woodcarving Illustrated Message Board This thread Refback 07-29-2007 04:14 PM
Honing stone? chipper67 Woodcarving Tools, Technology & Sharpening 10 03-22-2005 04:24 PM
Sharpening gouges and v-tools mikeg Woodcarving Tools, Technology & Sharpening 14 10-19-2004 05:05 PM
Sharpening my gouges k.grant Wood Carving for Beginners 23 01-19-2004 08:36 PM
Sharpening the Dockyard Micro-Gouges WhittlinWit Woodcarving Tools, Technology & Sharpening 6 03-03-2003 07:37 PM
honing strop Guest Woodcarving Tools, Technology & Sharpening 14 02-22-2003 06:38 AM
