Old 09-13-2011, 08:08 PM
nrscroller's Avatar
Default Santa head patterns?
HI
I am going to go to our local carving club this fall and there is a member that makes little santa head ornaments that is flat across the back. Anyone have a pattern for these, he just draws his from scratch. They are almost like a relief carving
Thanks
Old 09-13-2011, 08:15 PM
Bartster's Avatar
Default Re: Santa head patterns?
this months issue of wood carving illustrated has a article on the no-see um santa that can be changed 100 times to be made like you want it,
bart
Old 09-15-2011, 01:47 PM
brianrickman's Avatar
I do Santa face magnets too. I don't even bother with the pencil these days.
I start with a stick of basswood, about 1/2" thick, 1 1/2" wide, and 3" - 4" long. I taper the top 1/3 of the top to make a hat. I leave a square below the hat for the face, and taper or round the bottom to make the beard. These days I usually carve a ball on the top of the hat, and also taper the front of the hat from bottom to top so that there is a brim.
Here's an attempt at a very basic pattern:
Last edited by brianrickman; 09-15-2011 at 01:55 PM. Reason: Trying to fix the pattern
Old 09-15-2011, 02:00 PM
You can easily modify this basic pattern as you carve;
1. Make the brim of the hat cover the eyes
2. Make the hat taller or shorter,
3. Make the bottom of the beard round rather then pointed.
4. Make the beard or hat into a spiral
5. The facial details can be carved or just drawn on with a sharpie
6. Make the mouth open or closed, smiling or frowning
7. Glue in a bit of toothpick or pointed dowel for a really long nose
Bobble Head Santa Donald K. Mertz Caricature Carving 27 12-07-2010 07:35 AM
60 Patterns for Santa MDWine Reference Photos 5 11-11-2010 01:33 PM
Slide Show - Santa Head Cottonwood General Wood Carving 33 11-15-2009 01:47 PM
My First Flat-Plane Carving - Santa head PeterGander Flat Plane Carving 6 12-24-2008 08:39 AM
here is two Santa Ornament Patterns GaryMc General Wood Carving 1 11-22-2007 11:56 AM
