Old 05-13-2008, 06:57 PM
Default Question on newly-cut pine
Hi all,
I would like to try my hand at chainsaw carving. I have a huge inventory of pine trees on my property so I have free wood!
My question is related to taking down some pines and using them immediately in order to start carving critters.
Can anyone tell me specific wood preparation tips? Can I just start carving, or do I need to prep the pine with something prior to carving? Or do I just carve, and then treat it with something (need to know specifics on the something to treat with)?
Thanks muchly. I am a retired person looking for an interested hobby.
Old 05-14-2008, 11:34 AM
Default Re: Question on newly-cut pine
My suggestion is to have at it!!!
You have tons of stuff to learn and you will learn it as you work. (Mostly )
There isn't really a lot of prep work you can do when you are working with logs..........mostly what you are asking about is done when the sculpture is finished.
Here are some basics to keep in mind (esp when working with pine).
Strip the bark right away.
Checking occurs when the outer shell of the log dries and shrinks around the center which isn't. (drying and shrinking) The small to large cracks or "checks" will radiate to the center of the log......it's called the pith. This won't happen for a while but it will continue for a long time.
White pine cut at this time of year is loaded with water. Once the log is cut, this moisture, combined with hot weather will begin to decay. The early stages of this process will produce what is called "blue stain". It isn't a big deal till it comes to finishing it. That wood is punky and will absorbe paint and stain worse than end grain and will be the first places to rot if it's placed outside.......soooooo, don't cut more than you can use and store it in a cool dry place till you get to it.
My next piece of advise is...."Don't worry about it!!"
You are a beginner. Don't get attached to your first pieces.....it's just practice. You will learn faster by doing a lot of pieces rather than obsessing over your first ones.
BTW, Welcome!
Remember, this advice is worth exactly what you paid for it!!!!
Joe,
Make Chips!
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f33/question-newly-cut-pine-17395/
"Wood Carving for Beginners" | Forum Profile | BoardReader This thread Refback 05-26-2008 10:23 AM
I like pine Just Carving Carving Wood & Materials 12 11-26-2007 10:11 PM
Couple of newly finishedWoodspirits GaryMc New Projects and Works in Progress (WIP) 9 08-08-2007 09:36 PM
Newly finished Don Quixote RoundRiver New Projects and Works in Progress (WIP) 9 07-20-2007 09:34 PM
Newly hooked on carving - Hello! bbswampgirl Welcome Members 29 12-01-2006 09:28 AM
Question about Pine GWhite Carving Wood & Materials 22 06-22-2005 09:40 PM
Santa Carving Contest
