Old 03-09-2004, 01:52 PM
whittlin
Guest
Posts: n/a
Default Power Stropping
Currently I use a bench strop for my knives. I was thinking about getting a leather wheel for my grinder and using that as my strop. Has anyone used a leather wheel on a grinder? If so, do you put anything on it, like the Yellowstone compound? How do you apply it? Currently I take a cheese grater to the Yellowstone and butter it on the bench strop. It doesn't seem like this would work for a wheel. Do you just take the stick and apply it to the wheel as it is turning?
Thanks for any advice you can give me.
Old 03-09-2004, 02:11 PM
ah_chip
Guest
Posts: n/a
Default Re: Power Stropping
Whittlin,
I am no pro but I bought the power strop before I got a regular flat strop. I think I did more damage than good with the powor strop. My blade maitainence improved when I got the regular boring low tech bench strop. It was likely not the fault of the power strop but my lack of understanding at the time of the angles needed for sharp tools.
The bar of compound that came with my set just rubbed on as the wheel rotated. That was pretty straight forward.
My $0.02
Ah Chip
Old 03-10-2004, 06:59 AM
I use a hard felt wheel charged with Veritas green honing compound from Lee Valley. You charge the wheel while it is turning. I've got the wheel mounted on a bench grinder that I access from the back (the wheel must rotate away from you.)
Old 03-10-2004, 10:37 AM
rocket39
Guest
Posts: n/a
I've been using a power strop on my drill press for a couple of years with excellent results, this of course is running at a much slower speed than a bench grinder... 8)
Old 03-12-2004, 03:09 PM
Guest
Guest
Posts: n/a
I'm using both and also have better luck with hand stropping. I'm still experimenting with the power strop speed. Grinders (1725 rpm) seem to fast. My drill press has it down to 320 rpm.... better but how much lower should I go? Your grating the compound is good but I've taken one more step... at least on the first application to a new surface. I've put a few drops of honing oil on the leather and then worked in the compound. In a few minutes that stuff seems to cake on and stay. It like stropping on compound only. Maybe that's my reason for wanting to find the lowest effective power speed.
Old 03-12-2004, 06:56 PM
mdallensr's Avatar
Default It does a fine jobRe: Power Stropping
My Tormek has a 10' wheel with a leather surface for stropping after honing. It runs at 90 rpm and uses a paste compound that is refreshed with mineral oil. It also has a profiled leather wheel attached that lets you get the inside of bevels and v-tools. It does a fine job. I can't visualize the same wheel turning at 1725 rpm; way too fast.
Old 03-13-2004, 04:24 PM
dart's Avatar
Send a message via ICQ to dart
I use a piece of leather on a piece of wood. About 8'long by 1' square. I used red jeweler's rouge that I purchased at Sears. The electric grinder is way too fast for me. Builds up a lot of heat too. I have a 4' felt wheel on my dental lathe that runs about 1650 rpm and that's too fast. I have my wood lathe that I slow down to about 250 rpms and use a 6' rubber or 4' felt wheel on it with the compound. I polish a blade using very little jeweler's rouge. It doesn't take much compound. When the felt wheel gets clogged or won't take anymore compound , I use a 'horsebrush' to remove the excess compound while it's running. It really is not an exercise for a beginner to do. Many things can happen when using power tools. The best and cheapest way I've found is to use a variable speed reversable drill secured to my workbench. Set it at a slow speed and use a felt wheel chucked in the drill. The drill is also reversable. Just be careful that the drill is really secured to the work bench.
Wattles and Daub.
Old 03-13-2004, 05:42 PM
Mel
Guest
Posts: n/a
I saw a belt sander mounted on a vise, with 80 grit sandpaper, I wonder how good this works?
Old 03-13-2004, 09:13 PM
80 grit is awful coarse....I use the scary sharp method but only use 400, 800 1200 and 2000 grit.
Old 03-14-2004, 07:58 AM
Sounds like that 80 grit would be ok for a splitting maul!
I've use 400 grit and that takes a lot off in a few swipes!
stropping compound?? Dennis Taylor Woodcarving Tools, Technology & Sharpening 14 06-14-2006 05:36 PM
knife stropping ???????'s Dennis Taylor Wood Carving for Beginners 2 06-13-2006 10:05 PM
Stropping Compound Greyhair Woodcarving Tools, Technology & Sharpening 10 03-28-2006 09:45 PM
Stropping Question? Chizeler Wood Carving for Beginners 4 11-01-2004 10:13 AM
Stropping thoughts FatEddy Woodcarving Tools, Technology & Sharpening 8 01-14-2003 11:29 AM
