i would like some ideas and comments on the pros and cons of using reciprocating power gouges and other power bits such as the flexcut brand.
They are good for removing wood. The one I have is not real good on hard woods. But I love it for roughing out projects I do with cypress knees.
__________________ Randy May your neighbors respect you, Trouble neglect you, The angels protect you, And heaven accept you. |
| I have two Automach reciprocating carvers along with the box set of Flexcut blades. Here is how I use mine sitting in my recliner I can carve projects up to the size of a car battery. You don’t need a holding device like you would if you used a mallet. The other great thing is no dust just chips easy to clean up. Here are some detractors as I see it they are pricey my Automach $300 each and they are noisy. Another thing is if you only have one tool they will get hot in your hand after 30 minutes that’s why I have two of them. Don’t force the thing to cut and it helps if you can slice just a bit sideways with the larger blades mine will cut well with 1” gouges. |
Wayne, If you are already using a flex-shaft arrangement a reciprocating hand-piece is a good addition. As both Randy and Don have already said however, it is great for roughing out. Detail work, in my own experience, is nearly impossible. Also be mindful that using a reciprocating hand-piece requires a lower RPM (around 5K or so) to avoid overheating the tool. I have done some pretty heavy duty stock removal with a fairly wide gouge blade for extended periods, and not had an overheating issue. The Flexcut RG series blades (also in my opinion) offer the best bang for your $$$. As an added bonus you can get palm handles for them to use as a hand tool. L.P.
__________________ Mitakuye Oyasin, Inadv Rule 1: Don't part with your illusions. When they are gone you may still exist, but you have ceased to live. - Mark Twain Rule 2: There's no present. There's only the immediate future and the recent past. - George Carlin |
| Shortening full sized chisels and gouges | Kaity | Woodcarving Tools, Technology & Sharpening | 17 | 11-30-2011 11:19 AM |
| chisels vs. gouges | skip7083 | Wood Carving for Beginners | 4 | 07-10-2011 05:04 PM |
| what type of chisels and gouges to use? | hoovie26 | Wood Carving for Beginners | 14 | 01-25-2010 10:27 AM |
| Ashley Iles Gouges/Chisels on ebay | wade clark | Woodcarving Tools, Technology & Sharpening | 0 | 03-07-2006 07:04 PM |
| Chisels and Gouges | GWhite | Woodcarving Tools, Technology & Sharpening | 3 | 02-07-2005 06:28 PM |
