Old 11-10-2008, 07:17 PM
MichelleOH's Avatar
Default Pattern help
Is there a good place that explains how to use patterns? How to put it on the wood, how to cut it out, etc.?
Thanks in advance.
Old 11-10-2008, 07:22 PM
Bartster's Avatar
Default Re: Pattern help
michelle,
i learned how to cut patterns using pete leclair method in his carving bust book, other than that it is kinda trial and error, i used to just cut a side profile but now i use the front and side profile.
hope this helps
bart
Old 11-10-2008, 07:32 PM
MichelleOH's Avatar
Thanks, Bart. I have a friend that's asking about cutting out patterns, and since I'm a newbie, I can't really help.
I'll suggest the book.
Old 11-10-2008, 07:36 PM
Mark N. Akers's Avatar
MichelleOH:
i find it to be easier if you just cut a side view myself.
Old 11-10-2008, 07:52 PM
CarverFromNoWhere's Avatar
^Knife Junkie^
Talking Re: Pattern help
Depending on what I am sawing out I will cut side then double stick tape the peices back on and cut the front profile.
Carl
I know and can see clearly exactly what, I want to carve.
But on the long journey from my head through my arms,
So much is lost before it gets to my fingers and tools
Niin paljon puita, niin vähän aikaa
R.I.P Cliff Letty. June, 17 1937-Jan,8 2009
My Etsy store
My Youtube Videos
Old 11-10-2008, 10:47 PM
Mitchell's Avatar
How will you be cutting it out? I assume a bandsaw, but one can never be sure.....
If so, do a search "bandsaw patterns" - you'll get a lot that you don't need (or want), but there is some good info.
Here's one for example:
Much help need with blank and pattern
Old 11-11-2008, 10:52 AM
MichelleOH's Avatar
Thanks a bunch, everyone!
Old 11-11-2008, 01:41 PM
I tape it back together with masking tape around each cut piece.You can see the pencil lines thru the tape.
Double stick tape is much more expensive and gives you a space. Put side and front pattern on wood.
New pattern for Ron Ashbys Off Topic 7 02-21-2008 08:27 AM
Looking for a pattern Marci MN General Wood Carving 20 12-18-2007 04:39 PM
pattern mark faggion General Wood Carving 3 05-29-2006 10:42 AM
Need help with a pattern Nancy-ID General Wood Carving 9 03-28-2006 11:05 AM
Pattern Saud General Wood Carving 9 03-08-2005 11:02 PM
