Just bought me a bandsaw, and got the scrolling blade with it, so i can do rough outs...BUT...I'm have trouble cutting the them out. If i cut the side view first i can't seem to get the front proportions right, like the nose area is too low or too high for e.g. I believe that practice makes perfect but if thier are any pointers out there i could sure use them. Michael Gray
__________________ If your fingers are bleeding, your holding it wrong. http://visionsinwood.blogspot.com/ |
Micheal: I alway cut the front view first and then either on each side start at the bottom and top and meet leaving about 1/16th of a inch holding them togather or use scotch tape to stick the sides back on,you must put back on what you cut off to get a good pattern for the side view cut.
__________________ Mark N. Akers www.carvingsbymarkakers.com http://www.woodcarvingillustrated.co...00/ppuser/3670 |
grey wolf, mark gave you good information on how to cut out a pre-made pattern, but if your making your own pattern you need to draw, both side and front view on the same piece of paper, using elevation lines, maybe even graph paper... might help here OK, the elevation lines will set items identifiable in both views to the same elevation on the characature. When sawing don't remove to the line keep a little bigger, saw blade kerf or more 1/32 to 1/8th" even though the blade is at 90* it sometimes bends/curves inside the block when making corners or sweeping curves. make sure your table is level on the saw where the blade cuts at 90* the way i do it is with my scrollsaw, but the methods should be the same.
things like tilted cowboy hats are best left in a block as you cant cut the tilt without much difficulty... i leave hands in a block, as it allows me to change the way i might want to change the position at wrist rotation of the carving. then after you have the bandsaw rough out it might still take some interpretation of how the pattern is inside the block...i keep my pattern with my rough out so i can map out the block many times while carving and redraw features after i carve off the scrap... hope this helps a little.. Thomas
Previous discussions (somewhat related): http://woodcarvingillustrated.com/fo...t=bandsaw+tips http://woodcarvingillustrated.com/fo...t=bandsaw+tips As mentioned in some of the posts linked above, the more common terminology is "Bandsaw(n) blank". A "Rough out" is generally a carving that has been duplicated in to a rough stage. Also - Please consider safety first! Keep your blank flat on the the table when using a band saw...this is especially true when cutting both sides as you are describing. That's one of the reasons that the posts mention taping or glueing back the previous cut off pieces. My 2 cents: Make sure that the pattern is drawn correctly on both sides with key points used as matching reference points aligned correctly. For instance a nose and/or hand location. I make sure that the front and side patterns have these components match when put onto the blank by using a reference line drawn around the blank. I cut out the "easy" side first and then the "hard" (more detailed) second. When cutting the "easy" side, I don't ususally tape my pieces back on, instead I cut leaving just enough wood so the waste piece doesn't fall off. It's a bit difficult because you have to back the blade back out. I leave a "tab" at the top and bottom for support. I don't know how to describe this, so I will try to post a picture later.... Another KEY tip - make sure the pattern that you draw on each side matches front-back and side-side. In other words, don't flip the front view when transfering to the wood. This could cause "mirror image" type problems. This subject might be a good tutorial for someone to put up on the board....someone more talented than myself. Last edited by Mitchell; 10-23-2006 at 10:06 AM. |
and I thought ..MAYBE someday I would learn how to do this but I might as well forget it!!!! Is there anyway you could do this with a projector? No? I didn't think so .. Curtis bought this little projector but never used it and he mentioned making a pattern with it..Head Bange Charlotte
__________________ http://www.PictureTrail.com/santagibbs |
| Quote:
Claude |
| Quote:
Claude |
Charlotte, just don't over think it making good bandsaw or scrollsaw blanks is not hard, the mis conception is that you will have a near finished carving when your done, but your closer to a carving because you remove a bulk of the scraps.. actually you will have at least 9 pieces of wood left when you cut the pattern out of the block. sometimes when I'm making a lot of blanks i keep the 8 outer peaces and leave the pattern on them and glue or tape all 7 of the 8 back together to make a container for the blank to keep it safe and organized till i get the time to carve it. attached is a very small pattern (due to board-fourm constraints) for a banjo ukulele just something i found on a hillbilly search on Google. i took the image removed the background and just tossed together, the side view.. if enlarged to a usable size & printed then folded over a block edge and taped down, the front view of the pattern could be cut out then the loose pieces be taped back in place and then cut out the side view... now on a bandsaw i would cut the red lines, on a scrollsaw i would cut the black lines because you can control a scrollsaw better. on most cuts. comments and suggestions welcomed
Claude is correct - be very careful when backing out. I ususally cut so that the "waste" is loose, but not free - and then the kerf can be opened a bit to allow the blade to back out easier. Thomas has a good diagram showing the reference lines and how to transfer from the front to the side. I forgot to come up with a little instructional pictorial to go along with my previous ramble - sorry. Hopefully I can get it done in a couple of days. |
boy do i have alot to think over now! Thanks for the insites and info, ya'll got some very unique ways of getting the job done. As soon as i can i've got to try these ideas out. Michael Gray
| Woodspirit rough out | Mark Gargac | New Projects and Works in Progress (WIP) | 3 | 02-21-2007 08:05 AM |
| The art of the rough out | Spookhouse | Wood Carving for Beginners | 19 | 09-07-2006 01:08 PM |
| Rough out | wchips | Wood Carving for Beginners | 4 | 03-25-2006 07:29 AM |
| amimal rough out | crabman | Carving Wood & Materials | 0 | 01-16-2006 09:24 PM |
| which view do you rough out first?? | captgrant88 | Wood Carving for Beginners | 15 | 09-23-2005 12:56 PM |
