Old 02-17-2009, 01:54 AM
Unhappy Need advice with first project
I'm trying to carve out a wand from a branch about two thumbs in diametre. The branch was found on the ground but it must have broken off recently because it was still quite fresh.
I wanted to thin out the one end so that it tapers down into a semi point, but my boyfriend says that it will probably split. So I'm at a little of a loss as to how to continue with my project.
Can anyone offer me some advice, please and thank you!
Old 02-17-2009, 03:56 AM
Rwenzoski's Avatar
The Rube
Send a message via MSN to Rwenzoski
Default Re: Need advice with first project
Hi Rowan, If you put the stick in a plastic bag or wrap it in plastic & keep drawing the moisture out slowly it will not usually crack much or at all. If you just leave it out in the open & it dries to quickly this is what will cause cracking. Hope this helps?
Thanks, Robbin
index
Old 02-21-2009, 12:29 AM
Al_Hillis's Avatar
Hi Rowan , welcome to the board . I see Robbin has given you some excellent advice already
http://picasaweb.google.com/al.hillis/WOODCARVINGSMINE
Its better to take two steps forward and one step back then never having danced at all
Old 02-22-2009, 01:11 AM
Beautiful spirit sticks, Slather.
I was thinking of doing one as well. Is there any type of wood that you would recommend?
I need advice, please:) SeaChips Power Carving 5 02-23-2009 10:30 AM
Hello Everyone. I could use some advice, please. SquirrelMeister Welcome Members 12 01-25-2009 09:29 PM
I need some advice Colin-Partridge General Wood Carving 16 07-26-2008 03:33 AM
Need Some Advice Please John_M Wood Finishing and Painting 5 04-15-2008 07:57 AM
some advice...PLEASE! Keoma Woodcarving Tools, Technology & Sharpening 11 03-08-2008 09:00 PM
