Old 10-10-2006, 07:34 PM
Default Little bit larger tool
I have a beginner set of carving tools from Rick, I would like a few more maybe larger, doing just strickly Woodspirits, can someone recommend what might be a good addition to my current set, I have a Flexcut knife and a small detail Dunkle knife....tks in advance...Dennis
Dennis
Old 10-11-2006, 06:52 AM
mdallensr's Avatar
Default Re: Little bit larger tool
If by larger you mean wider, that's the progression I've followed. One of Chris Pye's 101 carving "secrets" is to use the biggest tool possible, and I agree. Most starter sets have narrow gouges and veiners, 1/8" - 1/4", and you'll find wider tools useful. I carve more with gouges now than with a knife. You can remove a lot of wood with a #7 or #9 x 3/8" or 1/2" in the roughing stage. Mike
Old 10-11-2006, 11:27 AM
Mike,
I have a set of the 1/2" Denny gouges that Rick sells, and would not hesitate to recomend them. They come razor sharp, and hold their edge for a long time. In addition to the 1/2" size, there are some available in 1/4",3/8" and 3/4" inch as well. Top quality tools in my opinion.
Happy Carving,
Dan Heine
Old 10-11-2006, 04:00 PM
That is what I am in the market for, somethng that will help remove wood quicker in the rough out stage, the set I got from Rick works great, but would like something to remove stock, just to get it out of the way...most of the carvings I have done, and maybe plan to do, is woodspirits, which I really like, and the sizes of those are from cane size to medium, can someone recommend gouge sizes, maybe a few tools to add to the beginners set, for medium work, the beginners set takes a while to remove stock...I was thinking maybe a larger gouge, maybe something flatter?....a larger V tool?....any input is appreciated...tks in advance...Dennis
Dennis
Old 10-12-2006, 11:31 AM
I'm a complete noob and have absolutely no carving experience.
But I have carved/am carving out a chair seat and removing a good deal of wood using an adze. The one I use is quite broad and shallow, but there are smaller, tighter adzes available for making bowls.
Could this work?
Old 11-14-2006, 03:42 PM
woodbutcher's Avatar
I have a #7 3\4 inch sweep with a palm handle that takes out alot of wood fast. I used it for years before jumping up to a full set of flexcuts standard chisels. Has my carvings started getting larger so did my tools. Good luck!
Larger Leprechaun Kenny_S Holiday 20 02-19-2007 12:28 PM
The V-tool Dennis Taylor Wood Carving for Beginners 5 06-06-2006 12:38 AM
Right tool for the job rick-in-seattle Wood Carving Tips and Techniques 12 04-29-2006 03:21 AM
What tool do I need... MrDantastic General Wood Carving 5 09-30-2005 03:59 PM
So what's in your tool box? capn_crunch General Wood Carving 18 08-08-2003 05:17 PM
