I'm having trouble getting into the inside corners like under her chin. The knife I have just can't get in there. It's the knife that comes in the littleshavers kit.
Any help would be greatly appreciated. Thanks, Marty |
the knife has the blade wrong direction for this, i would try a rather flat gouge, like a number 2, in a small width. i had such areas with mary poppins a lot, and mostly i used number 2 gouges, and sometimes a skew chisel, since that gives again another angle from the cutting edge to the handle...
__________________ my homepage ... and ... my wci gallery with galleries of my work ... and ... my blog with infos on the carving process |
Marty, I think you could get away without going all the way through...but if you have too, a fish tail gouge with a low sweep might be thin enough to work away the wood. Patrick |
Ok thanks guys.... that was kinda what I thought was a small chisel or a small flat gouge. Thanks a bunch, Marty |
| Quote:
Where can I look at a #2 gouge on the net? -Marty |
Try Ashley Iles tools suppliers - they have one in the US. Ashley Iles has a really wide selection of carving gouges. Here's one link that should help. http://www.toolsforworkingwood.com/i...did=IT-CONG.XX Last edited by hruukki; 03-04-2008 at 12:33 PM. |
marty, look here for exampple for a pic of the sweeps http://www.woodcarvingbiz.com/Gouges.htm i have the 2,5 and the 2,12 only, and so far i was always happy with it...
| Quote:
Are not these full size gouges? If I clamped the carving down I could use it. Is that what one would do? |
yes, full size ouges...and yes, i always clamp my work...i have much more control with 2 hands than with 1...
Those Pfeil gouges are great too, I have a few - they come from the factory polished, so a beginner knows what kind of condition they need to be for carving - it was very useful for me. If I remember right, Pfeil and Ashley Iles are about the same hardness. Iles might be a bit more expensive. Hard to tell if there is any difference in quality - Iles promises a lifetime warranty for workmanship though. I use hot-melt glue instead of clamping, if the carving is not very rough going. |
| Carving inside curves | Jaysonmol | Wood Carving for Beginners | 12 | 09-16-2011 01:20 PM |
| Sharpening inside bevel? | ChrisS | Woodcarving Tools, Technology & Sharpening | 4 | 02-06-2008 11:56 AM |
| Eagle inside mouth details ? | carvnman40 | Animal and Bird Carving | 5 | 01-10-2008 09:50 AM |
| Inside stropping of gouges and V tools | alarchie | General Wood Carving | 9 | 02-17-2004 11:03 AM |
| Inside the letters & frame - Questions | MikeD | General Wood Carving | 2 | 01-17-2002 08:59 PM |
