Old 05-01-2010, 11:45 AM
Default Gouge, sweep, etc and General Carving Tool Confusion
I am so confused about all the different terminology when it comes to carving tools. Many times I will read, use a #6 9mm gouge, a #10 4mm or #12 9/16" gouge, a 60 degree 2mm micro v-tool, etc. I go look at carving web sites for tools and see all kinds of #6 and #10 things, no 9mm anything, all sorts of other numbers and sizes and terms; sweeps, gouges, spoons, vtools and all sorts of combinations of metric and decimal fractional terms, for the tools, etc. I am so confused!! Is there somewhere that I can read that has the decoder ring for trying interpret all the totally confusing terms and tools? I just want to buy a few recommended tools but can't find the stuff because it does not match with anything in the catalogs.
Old 05-01-2010, 12:20 PM
arfer1943's Avatar
Default Re: Gouge, sweep, etc and General Carving Tool Confusion
It IS confusing.
English tools are numbered slightly differently to European tools for curvature, seen end on. No 1 is flat, 2 to 9 are (strictly) angular segments of a circle, the lower the number, the smaller the segment. See chart.
Sculpture Tools from Henry Taylor Tools Ltd.
Think of a slice of pie. A thin slice has a small curvature on the outside (no2), a half pie a very large one (No9). Then the diameter of the pie will give a wider tool but the same curvature.
Above no 9, you have "Veiners" which are curved at the bottom with flat walls (very useful). You then have "V" tools numbered higher.
You will have gouges with parallel sides and "fishtail sides". You have curved and back bent. They are all variations of the basic ones.
A pro carver may have 500 or more, using about a dozen for most work, but use others WHEN REQUIRED.
Look on the web for makers sets of about a dozen gouges and try to buy those patterns for your use. In due course you may want more, but by then you will know what you want.....
Good luck!
Old 05-01-2010, 04:40 PM
Mitchell's Avatar
Here's an old explaination: Have a dumb question - tool sweeps
A link to Pfiel chart of gouge profiles: http://www.woodcarvingbiz.com/Gouges.htm
Even more in-depth: Confusion About Tool Sweeps?
My WCI gallery
CCA Website Caricature Carvers of America
Old 05-27-2010, 01:29 PM
A_Swope's Avatar
Wildlife Carver
You can charts by searching on google. thats what I did
"Respect your efforts, respect yourself. Self respect leads to self-discipline. When you have both firmly under your belt, that's real power." Clint Eastwood
Old 05-27-2010, 04:43 PM
TreeWizard's Avatar
The only way those suggestions about the tools to use are any good is if the piece you are carving is the same size as that used by the instructor.
After a period of time you'll learn that you don't need all the gouges recommended, you'll be doing a lot of carving with only a part of the blade and you can make the same cuts with a #4 or a #6 by using only a part of the edge.
More importantly don't get hung up on the details, just enjoy the experience. You don't want your carving to look just like everyone's anyway. Put your own individuality into it.
Paul.
Old 05-27-2010, 05:42 PM
Beginning Carver
I bought the starter set from Flexcut and then added two because of an instructor's use of that same 'size.'
I never use more than 4 on any one carving -- and most often it's only 2. I use two or three knives -- based on how long the blade is and how much finesse I need to carve smaller details.
The Flexcut starter kit got me off to a great start -- that means I didn't get too much tool envy when carving at the club with other carvers nearby.
Don't discount starting small. It is still a viable approach.
LMiller
Question on the Flexcut 1 mm #9 sweep.... Just Carving Woodcarving Tools, Technology & Sharpening 7 04-04-2009 02:53 PM
making a tool handle for a flexcut gouge Dennis Taylor Woodcarving Tools, Technology & Sharpening 4 11-10-2008 09:36 PM
Confusion About Tool Sweeps? MJ1607 Woodcarving Tools, Technology & Sharpening 7 08-26-2007 05:21 PM
Gallery vs General carving woodtrapper General Wood Carving 2 01-31-2007 07:14 AM
general carving Guest General Wood Carving 3 03-21-2002 06:13 PM
