Lookin' good. Keep at it and in no time you'll be putting four balls in a cage. Just take it slow one little chip at a time.
#12
It looks like you're off to a reasonable start. Make sure you keep your knife sharp! That makes a big difference. mikeg |
#13
I've seen some great carvings done with only a knife so it can be done, just keep it SHARP as this helps alot..
__________________ Randal Last edited by R-OLDS; 05-09-2009 at 01:16 PM. Reason: ERROR in message |
#14
You are doing good.Try to stay inside the line[s]
#15
Thanks for the tips & encouragment everyone ! Started last night to carve away bits of the edges that will eventually form the ball.
__________________ -bluesK |
#16
So far so good .. keep it up .. your following your pattern very well Gene
__________________ G.M. |
#17
Looks good so far. Carved a few of those myself using the same type of knife. Gotta keep it sharp...Usually from the factory, the angle at the blade is too steep. I modified my blade angle (redefined it) to a more shallow angle and the knife cuts much better. Keep up the good work and keep us posted... Just my $0.02
__________________ "Life is Wood..." Hammer |
#18
You're off to a good start. At the risk of confusing you, I've included a link to a photo in my gallery: This one is carved of butternut. Ball in Cage - Wood Carving Illustrated Photo Gallery I usually bore through the blank at both ends and in both directions. Then I leave those curved openings as part of the ends. You can also embellish the corner posts and the ends. I like to leave the ball loose but tight enough to "stick" in the middle. It emphasizes the "ball-in-cage" aspect. Last edited by pallin; 05-14-2009 at 01:57 PM. |
#19
ok i've heard so many stories about the ball n cage but never seen one does the ball actually move? i want to take a go at this tonight. i just started carving a few months ago and really love it already i've done 2 mountain men but want a new challenge
#20
The ball does indeed move in the cage. There are several sites online that tell how to do it. Here's a reasonably good one. How to Whittle a Ball in a Cage (with pictures) - wikiHow
__________________ Jim My carving blog posts I've never sold a carving, but I've collected a fortune in smiles. |
| Another Ball in a Cage | keithlong | Wood Carving for Beginners | 17 | 10-08-2008 05:37 PM |
| ball in cage | stickman | Stick and Cane Carving | 11 | 09-07-2008 02:36 PM |
| Golf Ball Cage | Mark N. Akers | Caricature Carving | 30 | 05-13-2008 09:57 PM |
| Ball In a Cage - 1st attempt | brushpilecarvings | New Projects and Works in Progress (WIP) | 4 | 08-08-2006 08:58 PM |
| BALL IN CAGE | STEVE | General Wood Carving | 5 | 03-15-2003 10:07 AM |
