When the carving is completed what is the best way to clean the wood before you paint project?
__________________ Bill Murphy ![]() One Thumb Carver Georgia USA Best Describe-LearningTo Carving "Success consists of going from failure to failure without loss of enthusiasm” Winston Churchill |
I use a bar of white hand soap and an old toothbrush. Wet the carving under the faucet, scrub with the soap, rinse under the tap, then dry with a hair drier. It'll feel rough because of raised wood fibers, but a few passes with some 400 grit sandpaper, or a wadded up brown paper bag, will make it feel smooth again. Claude |
I stay away from trying to "wash" a carving as you will never be able to get rid of all the cleaning solution no matter how much you might rinse it. The best thing to keep a carving from needing a trip to the sink is to just wash your hands occasionally and make sure your carving glove is clean. Stay away from those rubber nibbed gloves as the rubber breaks down over time and creates a real mess on your piece. I use a Sand'O'Flex wheel to lightly sand my pieces when their finished and this removes any dirt collected on a raised surface.
I don't wash my carvings at all, I use the 3M discs in my Dremel and go over the whole carving! I will try to find you a link to the discs. Dave |
Thanks Claude, Lynn O Doughty and Gulf Coast Handyman for taking time to respond to my question.
Ditto with Lynn's statement re: keeping your hands clean. Me, I keep the pencil marks to a minimum, which helps keeping the carving clean (But that's not why I don't use a pencil - it's because I work so fast that pencil lines never last long enough to convey any meaning. But that's another subject). Oftentimes I'll use a V-tool to 'sketch' in lines, in lieu of a pencil. S~
__________________ Carvito ergo sum |
Scooter, I have heard about you working very fast and also that sometimes you have to slow down so the V tool will not burn you wood. Thanks for you in put have a good day
| Cleaning Wood | Robson Valley | Wood Carving Tips and Techniques | 5 | 12-05-2011 10:11 PM |
| Cleaning Up After Yourself | kdispoto | Off Topic | 12 | 01-30-2011 11:33 AM |
| Bur cleaning | John_C | Power Carving | 16 | 08-27-2010 11:28 PM |
| driftwood cleaning | Wes Leitch | General Wood Carving | 3 | 09-08-2008 07:34 AM |
| Spring Cleaning | Dan S | Caricature Carving | 19 | 08-23-2008 10:39 AM |
