I have read about using oven cleaner and burning for Kutzall/Typhoon burs and oven cleaner for metal burs but how do you clean diamond and ruby type burs? As you can tell I'm a newbie at this power stuff.
I use a rubber sanding belt cleaner. You can get them at most hardware stores.
__________________ Visit my online gallery at: http://www.jaminmark.com/das/gallery.html |
power carving annual offered the following for cleaning burrs 1 tungsten carbide burrs are brushed clean with a brass bristel brush if a steel bit is severly clogged use a propane torch to burn resin when resin is charred brush out crevices 2 to clean ceramic bits lightly touch the bit to a fine diamond honewhile bit is rotating.this method removes resin and a thin layer of the stone itself. 3 soak ruby and diamond bits in oven cleaner for several minutes.then wash in clean water and scrub with a brass bristel brush.
__________________ http://www.picturetrail.com/jamesfa |
| Cleaning up old wood | Irishman | Carving Wood & Materials | 5 | 11-12-2006 06:52 PM |
| Cleaning the shop | Doug Ridley | Off Topic | 14 | 06-26-2006 07:25 PM |
| Time for some cleaning | mwilleson | General Wood Carving | 7 | 02-06-2006 10:08 AM |
| Power carving bits and burs RPM rating question | woeco | Woodcarving Tools, Technology & Sharpening | 10 | 10-21-2005 12:44 PM |
| detail cleaning | Alice in Wonderland | General Wood Carving | 12 | 12-23-2004 11:18 PM |
