  #31
Old 05-12-2008, 10:54 AM
Default Re: Carved face - first carving
Hello : Faces are expressions, expressions are feelings, expres feelings thru wood is liberating. What you need now is sanding to "clean" the marks of chisels.How ? Use a dremel rotary tool, with a light variation to an accesorie that will make it very easy. I do faces on pine using mostly bifurcation , yokes so the face will happen on the strongest part of the wood , for this type of faces like tikis is better use hardwoood , the harder the wood , better the expressions. I did lately a chess play out of branches of a hardwood, with 16 different expressions, try it.
Old 05-12-2008, 05:46 PM
Ashbys's Avatar
Tito ,
I am courious, are you saying you doing your carvings with expression based upon the mathamatical changes of the face expression ? So one contour forces another contour , in a measured way ? Then planning the face using the grain to make the grain contours to high light the face ?
Or excatlly how are you using the term bifurcation ?
I really do not know what you mean when you say you made a chess with 16 expressions. Could you show me. Or did you mean chest either way would love to see what you mean .
Thanks
Ash
Ash
Carving A Simple Face On A Golf Ball ..A Beginners Tutorial gene messer Wood Carving Tutorials 21 07-06-2008 07:49 PM
Carving A Little Guy Face In The Flat Plane Style gene messer Wood Carving Tutorials 24 12-11-2007 12:26 PM
question about carving frontal face views Ashbys Wood Carving for Beginners 9 09-03-2005 09:55 AM
carving human face Guest General Wood Carving 11 01-28-2003 03:50 PM
carving human face Guest General Wood Carving 0 01-14-2003 08:51 AM
Santa Carving Contest
