Old 03-09-2011, 11:42 AM
Buffalo Bif's Avatar
Buffalo Bif
Send a message via Yahoo to Buffalo Bif
Default For beginners- sharpening & 5Min projects
I'm a new-ish whittler myself, only 3years or so, but thought I'd share a couple epiphany's I've had lately.
When your knife seems dull, take a looooonnng visit at your strop, and use fresh compound. I was getting frustrated when my knives seemed to hold their edge for less and less time until I realized the small amount of time I was spending with my strop was the problem. I applied some new compound and gave each side of my knife 50-100 strokes on the strop and became happy again. I had only been stropping for 10 or 20 strokes on old compound, and it wasn't enough. The knife would get better, but it never became great. I don't do that every time I strop, but I do it regularly.
The second thing I've come to realize is that those 5 minute projects (owl, gnome, whatever) take a lot longer for the first few you do. Maybe for the first hundred even. I watched a couple vids and slide shows, and proceeded to spend hours working on the project. It wasn't till I whittled a couple dozen (not quite identical) holiday ornaments that I figured out repetition was the key. The first ornie I did took hours, the last one turned out better in my opinion, and only took 30 minutes. Not sure I could get that one down to 5 minutes, but you get the point.
I'm sure all this has been posted here at one time or another, I thought I'd add my own encouragement tho. Keep your chin up, keep your bandaids close, and keep trying.
Brian
BuffaloBif
What one man can do, another can do.
My Blog
Old 03-09-2011, 11:54 AM
idigjars's Avatar
Carver Wannabe
Default Re: For beginners- sharpening & 5Min projects
Good tips on the sharpening. You are right about those 5 minute projects, they take me a lot longer than that. :-) Take care. Paul
Old 03-09-2011, 02:08 PM
Thanks for the reminder to freshen up the compound... I also get lazy and try to use the slightly grayed remnents... I don't know that I will do 100 strokes but I agree more the 20 will help.
Good stuff!
Richard
Old 03-09-2011, 02:43 PM
I clean and recharge my leather strop before every honing session. I was taught to use a 6" mill file edge (not the flat, the edge) as a scraper and go gently maybe 5X. Scrape the cruddlies off the file with a stick. Streak the compound onto the strop with quick motions to heat up the cpd a little to get more on the strop.
2 projects in finishing stages, I get to use my 5/35 all day!
Old 03-09-2011, 04:04 PM
Gulf Coast Handyman's Avatar
100 Strokes per side, you have alot more paitience then me! LOL A couple things that helped me in the stropping dept. were, Cape Forge sells a liquid compound, 10 strokes per side every 20-30 minutes is all it takes. Also I built a power strop with a 1x30" belt sander hung upside down and a $15.00 leather belt, works awesome! The last is a 5" disc with leather attached, chucked into a mini drill, also works great! ( Got the idea from Arleen Zomer, from carverswoodshop, she has a Youtube video on sharpening). Hope this info. helps! BTW- I totally agree with fresh compound!!
Dave
Old 03-09-2011, 04:12 PM
Here are a couple links. Sorry, I tried to attach a picture of the 1x30" power strop but it is not working.
Carving Accessories at Cape Forge
YouTube - sharpening secret #1
Dave
Old 03-09-2011, 06:10 PM
Buffalo Bif
I am dreaming of a power strop, especially when making new knives. Soon, I have promised myself.
Brian
BuffaloBif
My Blog
Old 03-09-2011, 06:35 PM
Well you make some beautiful knives, so you deserve one.
Dave
Old 03-09-2011, 06:36 PM
North of 49
My late mentor was a man who followed stropping seriously but felt that occasionally, an edge had to "smartened up" with the touch of an 8K slipstone. In my view, it works. Power strops are nice too.
Old 03-09-2011, 07:47 PM
Claude's Avatar
I don't bother cleaning my strop - it hasn't been cleaned in at least five years. I use thin suede leather with the green compound. I also give my knife a few strokes every 15 - 30 minutes. I do five strokes on one side, five on the other, then four on the first, four on the other, then three... total of fifteen per side. I apply some pressure, but make sure I don't lift the back of the knife up appreciably so I can avoid rounding the edge. Two keys to stropping; thin leather and steady movement that doesn't lift the back of the blade as you pull it across the strop.
I also use a small piece of basswood that has flexcut gold rubbed on it for my detail knife. This knife is very thin and flexible, so I need to be careful about rounding, and the basswood with compound works well.
As I said, this is what I do; others may do differently. Try several different things and see if one of them keeps your blades sharper. Use that one.
My web site
Three New Beginners Projects gene-messer Wood Carving Tutorials 6 08-22-2010 09:20 PM
Where did I see that owl for beginners? INSilverado Wood Carving for Beginners 12 04-28-2010 04:32 PM
Beginners Projects gene-messer Wood Carving for Beginners 9 04-11-2010 11:02 AM
free youtube projects 30 plus projects online for free carverswoodshop Online Wood Carving Classes 12 01-19-2010 02:15 PM
